67 Users Online (66 Members):
Forums >> General Discussion >> Revit Project Management >> Insulation
Morning everyone, i'm in the process of making sleeve drawings(wall penetrations) for mechanical pipe. I have a rather complicated mechanical system. therefore to minimilize confusion for the field guys i isloated the heating hot water, and the chilled water from one another and created views from each, so i could apply them to two differebt sheets. But i have ran into a quite frustrating situation. Since i can specifically select the insulation i cannot do a hide/isolate to segragate the hhw from the ch and see the insulation. a way i thought i had figured it out was: i just removed the insulation and added it after i applied the hide/isolate, but if i do that it appears in the other view and i've entered a circle of frustration, not fun. if anyone out there has any advice, i'd greatly appriciate it, thank you for your time.
Okay, i got it. I had to select all pipe in HHW, edit insulation and save the insulation as a selection. deselect everything, highlight all walls firstwith select all in entire project, then highlight everything in the sheet that i wanted, then load the saved insulation selection to get it to appear. for any of you having the same problem out there.
Plumbing insulation |
Thu, Feb 20, 2014 at 8:19:48 AM
insulation line |
Fri, Dec 1, 2017 at 9:57:58 AM
Hide insulation in MEP 2012 |
Wed, Sep 5, 2012 at 3:39:14 AM
Spot elevation Tag and Insulation |
Wed, Jun 11, 2014 at 10:00:27 AM
Batten Insulation - System Wall - Section |
Thu, Feb 16, 2012 at 1:10:29 PM
Members: | 1993919 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
