75 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> Roof texture problem.
I have one strange issue, I tried everything. I added easily texture for my walls, but when i tried add texture to roof, only bump works. The texture is visible on specimen, but roof is just gray. Anyone had this situation? Please help, deadline is near.
I don't understand the problem, you can't add a material to your roof?
I added material, with texture, but, texture doesent appear on rendering, only texture bumping. Dont know why.
Something is wrong in your process. I suspect that you did not create your material correctly. Paint it on a wall surface and see if it works there. If not, then you have found where your problem is.
Got a problem with texture orienting from a imported revit model in 3DS MAX 2008 |
Tue, Mar 31, 2009 at 10:15:40 AM
Giving the roof the texture of a roof tile |
Tue, Sep 10, 2013 at 8:28:20 AM
Creating Realistic Texture For Roof |
Tue, Feb 26, 2019 at 1:37:49 PM
Texture Map Gets Messed up after cut. (revit 2013) |
Mon, Jul 1, 2013 at 9:10:10 AM
Texture fix |
Mon, Jul 9, 2012 at 1:25:13 AM
Members: | 1994524 | Objects: | 22882 | Forum Posts: | 152181 | Job Listings: | 3 |
