83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stuck in Yellow Screen
Thu, Jan 2, 2014 at 1:00:35 PM | Stuck in Yellow Screen
jsego
Hello,
Sometimes when I am working, I double click on something and get stuck in group edit mode with the yellow screen.  The Finish and Cancel options are greyed out and everytime I click, it says "Can't delete element that is being edited."  Has anyone ever had this happen?  I mess around with it for a while and finally get out of it, but I would like an easier way to get out of it.
Thank you!
Thu, Jan 2, 2014 at 1:04:59 PM | Stuck in Yellow Screen
3.5 Stars: 391 Votes
We ask posters to include the issue of the revit they are using and what updayes they have installed.  Do that and we may then be able to help you.
Thu, Jan 2, 2014 at 1:05:42 PM | Stuck in Yellow Screen
jsego
It's 2014 and no updates installed yet.
Thu, Jan 2, 2014 at 1:07:00 PM | Stuck in Yellow Screen
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
There are 2 updates available with 2014, you need to install those updates.
Thu, Jan 2, 2014 at 5:26:20 PM | Stuck in Yellow Screen
eriege
1 Stars: 1 Votes
I am very sorry to be spamming your reply box with my question but.. I just wanted to know how to post a thread on the forums. Thank you
Fri, Jan 3, 2014 at 4:51:14 AM | eriege
4 Stars: 201 Votes
Quoting eriege from 2014-01-02 17:26:20
Goto our "FAQ" page please: http://www.revitcity.com/faq.php
Thu, Mar 6, 2014 at 9:19:59 AM | Stuck in Yellow Screen
miaojixu
Ctrl+Z should get you out of it!
Tue, Mar 11, 2014 at 6:17:44 PM | Stuck in Yellow Screen
RLAKES
CTL+Z worked for me.
I hope the updates do too. 2014 seems a little buggy.
Tue, Apr 29, 2014 at 12:46:19 PM | Stuck in Yellow Screen
alau1
Found this somewhere else:
"By default, the Edit Group panel is a 'torn off' panel that should be floating in the upper left corner of the drawing window. It can be "returned to Ribbon" where it will dock itself on the right side where the contextual tools will be. If you can't find it, it may be on another monitor?"
Hope that's what you are looking for!
Fri, May 2, 2014 at 5:13:45 PM | Stuck in Yellow Screen
ziemo1
2014 with all updates loaded
it happens to me also, generally when i'm coping text. i palce the copied text and try to change it this happens. haven't heard of the "control z" thing will have to try it. i usually end up closing out of the program, it will ask to save the project.
sure is a real pain in the curse...
go revit
weird yellow render RAC2009
Tue, Jan 6, 2009 at 2:29:31 PM
void in family is yellow
Mon, Mar 12, 2018 at 12:22:43 PM
Loading Curtain Wall Door Types
Thu, May 7, 2009 at 10:07:37 PM
What do your desktop screen looks like.
Fri, Mar 30, 2007 at 5:17:56 PM
Fly screen doprs!?
Fri, Dec 15, 2006 at 4:50:25 PM
Page generation time: 0.3427
