160 Users Online (159 Members):
Forums >> Revit Building >> Technical Support >> Lights in Rendering behaving badly
Has anyone encountered this problem before (attached)? I inserted a family from a lighting manufacturer and the IES file that was part of it seems to be making Revit throw up....a bad render output.
Some initial research shows that there has been an issue with IES files in Revit and that it has to do with Absulte IES files:
http://forums.autodesk.com/t5/Revit-Architecture/Problem-rendering-when-using-an-quot-Absolute-quot-IES/td-p/3120130
Has anyone been successful editing the IES file and then rendering in Revit the way it was done in the linked article?
I saw this problem once, I believe you can solve this if you "Play" with "Adjust Exposure".
I'll give that a try!
I still haven't had any luck here. Seems like all ies files are creating problems in Revit rendering environment. Does this work in 2014? I;m still running 2013 until january.
Any new insights on this? Do IES files work at all in Revit renderings? So far all I ever see are rainbows from the lights. Enlighten me!
rendering: can't get itnerior lights turned off |
Mon, Feb 27, 2012 at 6:14:44 AM
lights not working in 3D or rendering |
Thu, Jul 11, 2013 at 10:56:36 AM
Exterior night rendering with interior lights on? R16 |
Wed, Aug 3, 2016 at 1:23:36 PM
artificial lights not rendering |
Tue, May 7, 2013 at 6:52:56 AM
Interior rendering with lights |
Wed, Sep 29, 2010 at 8:50:38 AM
Members: | 1998541 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
