82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> Wall Footing on Walls w/ Modified Base Extension
25 Posts No Rating |
I am having a tought time figuring this one out. I am using Revit 2014 and have a multi-layered wall (CMU-Mtl. Stud-Gyp Bd.) and have unlocked the CMU layer to exented it 1' down to the wall footing. The issue is that when I apply a wall footing from the 'Structure - Wall Fountain' icon it applys the footing to both the extended CMU portion (which is the structure on the wall assembly) as well as the Metal Stud portion which stops at the slab. Any idea on why this is happening? Check out the pictures attached.
Palm Springs Architect using Revit LT! |
I had never had this situation so I tested this and it works exactly as you say. Your solution is to use a seperate stem wall.
Thanks WWHub. I figured that is what would have to be done. Stange bug/issue though.
Double footing problem - plz help?? |
Thu, Nov 15, 2012 at 3:24:50 PM
Wall Footing Issue with Placement |
Sun, Nov 21, 2010 at 9:22:07 AM
Wall Footing for copy monitored element. |
Tue, Jan 22, 2008 at 4:25:40 PM
Wall Joins Disappear When Base Extension Distance Parameter Not Zero |
Wed, Oct 12, 2016 at 3:26:45 PM
Attaching a footing to a column with a base plate nested into the footing family |
Thu, Jul 11, 2019 at 12:23:42 PM
Members: | 1998346 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
