72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> HATCH 22- REVIT MODEL HATCH
Fri, Nov 8, 2013 at 12:38:57 PM | HATCH 22- REVIT MODEL HATCH
sshneyer
GUYS I NEED A NORMAN BRICK HATCH WITH THE EXACT DIMENSIONS BELOW. CAN SOMEONE HELP ME OUT I SPENT HOURS ON HATCH 22 AND CANT GET IT TO WORK!!
THANK YOU!
Fri, Nov 8, 2013 at 1:12:59 PM | HATCH 22- REVIT MODEL HATCH
sshneyer
NOBODY TRIED USING HATCH22 PLUG-IN BEFORE?
Fri, Nov 8, 2013 at 10:35:11 PM | HATCH 22- REVIT MODEL HATCH
hugh
3.5 Stars: 4 Votes
Try this:
;%VERSION=3.0
;%UNITS=INCH
*NORMANBRICK1-3RUNNINGBOND,horizontal 11.375"x2.375" bond=1/3
;%TYPE=MODEL
;        Pattern written by HatchKit 2013 Hatch Pattern Editor
;        HatchKit 2013 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2013.
;        www.hatchkit.com.au
-90,15.295,5.123,0,11.75,2.375,-3.125
90,3.9199,2.748,0,11.75,2.375,-3.125
0,3.9199,5.123,0,5.5,11.375,-0.375
180,15.295,2.748,0,5.5,11.375,-0.375
-90,11.375,2.375,0,11.75,2.375,-3.125
90,0,0,0,11.75,2.375,-3.125
0,0,2.375,0,5.5,11.375,-0.375
180,11.375,0,0,5.5,11.375,-0.375
Hugh Adamson
www.hatchkit.com.au
Sun, Dec 8, 2013 at 12:13:15 PM | HATCH 22- REVIT MODEL HATCH
mertens3d
5 Stars: 2 Votes
sshneyer,
Can you let me know what problems you were having with hatch22?
Thanks,
...gregory
...gregory
http://mertens3d.com
my Revit - Bugs/ Issues/ Requests
Thu, Jun 26, 2014 at 4:58:56 AM | HATCH 22- REVIT MODEL HATCH
hugh
3.5 Stars: 4 Votes
I am very pleased to finally get to the point of offering a public beta of HatchKit 2014 for all interested to trial and perhaps comment upon while we ready  release versions.
Link:  http://www.hatchkit.com.au/hk2014betaofferform.php
HatchKit 2014 Beta works as a standalone application or will integrate with the HatchKit Add-In for Revit that is available from the Revit store at Autodesk Exchange.
Link:  http://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3ahatchkitadd-in%3aen
The HatchKit Add-in for Revit allows large patterns exceeding the constraints on scale imposed by Revit's pattern import wizard to be loaded from HatchKit 2014.
HatchKit 2014 and the HatchKit Add-In for Revit work together to allow building a hatch pattern template (the entities repeated to for a pattern) within Revit, manage its passage to HatchKit for pattern arrangement and generation and on return bring the finished pattern into Revit for immediate use within the current project.
No DXF or PAT filehandling is required - all information transmission between HatchKit and its Add-In within Revit is automated.
The HatchKit 2014 Beta will operate until 1st September 2014 alongside any previous version of HatchKit to allow flexibility of operation in a production environment.
Please contact me if you have any question or suggestion regarding HatchKit.
Hugh Adamson
www.hatchkit.com.au
Fri, May 8, 2015 at 3:01:04 AM | HATCH 22- REVIT MODEL HATCH
hugh
3.5 Stars: 4 Votes
HatchKit Add-In for Revit 2016 is now availableto download from Autodesk's Revit  Exchange
https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3ahatchkitforrevit2016_windows64%3aen
Hugh Adamson
www.hatchkit.com.au
Sloped Hatch Pattern
Fri, Oct 2, 2009 at 1:57:19 PM
Number hatch for ceiling plan
Mon, Dec 17, 2007 at 12:48:09 PM
Downloading a new hatch and applying to Revit... how?
Mon, May 23, 2005 at 8:34:27 AM
12
Control Hatch Display
Tue, Jan 10, 2012 at 10:26:34 AM
hatch scale?
Sun, May 10, 2009 at 3:33:47 PM
Page generation time: 2.7016
