38 Users Online (37 Members):
Forums >> Revit Building >> Technical Support >> Pattern files
35 Posts No Rating |
I have a pattern file I would like our students to use, where are the .pat files kept??? I can't find them anywhere (sheesh!!!!)
----------------------------------- AutoCAD & Revit TAFE teacher from regional Australia |
3 Posts No Rating |
Hi
The Revit .pat files are kept in Crogram FilesAutodesk Revit Building 9Data
I've moved and keep all our pat files in the actual network library. Much easier than locally on each workstation. It doesn't particular matter where they are kept, revit on references these files when you are loading a new pattern.
HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Pattern (.PAT) Files |
Mon, May 3, 2021 at 4:51:04 PM
Use Pat Files |
Tue, Sep 1, 2009 at 4:18:40 AM
11
Pat files corrupt |
Thu, Jan 22, 2009 at 3:20:12 PM
Patern Files |
Wed, Nov 16, 2005 at 2:53:56 AM
Floor pattern not showing up when the pattern is model pattern |
Fri, Nov 3, 2023 at 9:11:59 PM
Members: | 2003364 | Objects: | 22887 | Forum Posts: | 152186 | Job Listings: | 3 |
