148 Users Online (147 Members):
Forums >> Revit Building >> Technical Support >> Callout Wont mirror, Need help !!!
9 Posts No Rating |
hey Guys need some help here
SO had to mirror my project and everything is fine except most of the callouts havnt mirrored with the project,
when i take off the 'cropped view' in the callouts , the view shows the floor plan back to how it looked before mirror ?
any suggestions how i can change the view in the call outs to look the same as the floor plans?
North points are all fine, just the view on screen is still the same as before( not mirror)
Please HELP !! :S
What Revit? What updates? Maybe you just didn't install the fix.
9 Posts No Rating |
Revit 2012, Updates?
Not sure mate, does it sound weird for everything else but the callouts to have mirrored ?
9 Posts No Rating |
ok so just made a test file to see what i may have done wrong.
The process i took to rotate the project was to "mirror" East-West and then again "Mirror" North-South, hoping by doing this it would keep everything still inline
So what i found out is it works fine East-West, but as soon as i rotate North-South the Callout reverts back the orginal view
Am i maybe taking the wrong precess to rotate the project?
9 Posts No Rating |
*UPDATE*
Probelm solved, So realised when u mirror a project west to east the callout change with it, north to south they dont, so just have to go around to all the callouts on the floor plan, click on the outline of the callout and rotate the callout its self
Hope this helps if anyone finds themselve in the same situation
2012 had 2 updates. Working without those updates will only give you problems.
Have you heard of "Mirror project"? Obviously not so read your help. This process works better than simply using the mirror tool.
9 Posts No Rating |
ahah mate wouldnt use the 'mirror tool' your refering to to mirror the whole documentation
Mirror project, thats why i refered to the N/S & W/E option
and was up to date with the software so was no issues there
Thanks so much for the follow up - have a 300,000sf project I had to use the "mirror project" and had the same issue with my callouts, which were in the dozens. I appreciate the "rotate the callout" as the fix, as it is working great!
Sincerely!
Callout head wont display |
Wed, Sep 1, 2010 at 10:12:14 PM
using the mirror comand [ 1 2 ] |
Thu, Oct 15, 2009 at 9:13:36 AM
17
HELP... need to mirror a plan |
Wed, Jul 2, 2008 at 12:27:55 PM
12
Mirror Material in Revit not Working |
Tue, Sep 23, 2014 at 5:49:41 AM
can Callout duplicate detailed drawn on section view? |
Thu, Oct 4, 2012 at 11:05:02 AM
Members: | 1992634 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
