66 Users Online (64 Members):
Forums >> General Discussion >> Revit Project Management >> Linking Revit Models
We have just received the Revit survey for our building which I want to overlay on my model. The problem is when I link the survey model to my model it disappears and I can only see it through a 3d view. I have tried to locate it through an elevation view by moving the elevation extends and crop regions out but I still cannot see it. What is the best way to link/Overlay Revit models?
See this link for information on Shared Coordinates.
http://paulaubin.com/_downloads/2011_AU/Papers/AB3733_Aubin_SharedCoord.pdf
Do you mean the site is off to the side? ... or below your model elements?....
You say Revit survye but do you mean a CAD dwg or really a Revit Model?
We are renovating a building which I originally drew by inserting dwg survey drawings into my revit project.
We have now recieved a revit survey of the building which is more accurate. ( I have now managed to overlay the survey model over mine)
Is it better to:
1. Delete my existing information, then copy / paste the existing information from the survey model into my model or
2. Delete my existing information and have the survey model referenced into my file.
I will need to remove existing openings and add new openings into the existing walls.
Link in the topo into your project using the information in the link I gave you.
Linking models with multiple sites |
Wed, Dec 6, 2017 at 9:43:09 AM
Linking Other Models |
Tue, Aug 31, 2010 at 1:35:54 PM
Linking the Autodesk Advanced Models Together |
Mon, May 19, 2014 at 2:02:04 PM
linking models via origin to origin problem |
Wed, Sep 30, 2015 at 10:20:09 AM
linking models into models |
Fri, Aug 24, 2007 at 12:55:28 PM
Members: | 1999800 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
