38 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> LINKING VIEWS
41 Posts No Rating |
I have 2 front elevations for the same house. The same two elevations when mirrored are designed to fit on a slightly different house. My original solution was to use the design options but the custom generic models and profiled walls do not want to cut out of the original model. So my next idea is to link the optional front to the original model. I am not getting this right either. I can add the whole model of the optionsl front to the original but I can't figure out how to just link a view. Is there a way to keep from doing 4 complete models?
Design Options should work for this. Remember that you need to included everything you want to see in an Option in order for it to show up. But it sounds like you have you have 4 houses with 2 pair in each that look the same. If you want to see all 4 on one view, you will have to build all 4. If you have built 1 and 2 already just copy them and change the front elevation as required.
HELP! ALL of my plan views vanished!!!! I've tried creating new views |
Wed, May 9, 2018 at 3:18:43 PM
Linking models with multiple sites |
Wed, Dec 6, 2017 at 9:43:09 AM
Linking Revit Files for Sheet Coordination |
Fri, Jul 10, 2009 at 11:09:09 AM
Linking 3d views to call outs |
Wed, Jun 2, 2010 at 3:59:39 PM
Collaboration and dependent views |
Fri, Jun 9, 2017 at 10:14:43 AM
