67 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Painted surfaces
4 Posts No Rating |
I need to show an existing building with new materials on the exterior. I have three phases set up - Existig, demo, New construction. I am working in new construction when I paint the existing wall yet it shows up on the existing phase as well. I am placing both of these drawings on a sheet to show the changes. How do I mak this work?
Thanks
Paint is a model change, not just an image change.
Your best method is to change your wall so that it does not incude the exterior skin. Then add a thin wall (existing phase) on the exterior that is your existing exterior. You can then show that - and demo it. Then have another new phase thin wall with your final exterior.
4 Posts No Rating |
Thanks for the advice. It's a good idea but unfortunately at this stage to make a change like this will require a tremendous amount of rework. The structure is a bit complex. I think this time around I may just save two verisons of the file. One showing the existing and one showing the new. When it comes time to plot, I will just print the existing from the one file and add into the new. If there is a simpler way, I'm all ears.
Thanks again
How to take quantities from painted surfaces? |
Tue, Oct 10, 2017 at 1:00:43 AM
Revit 2014 . rendering in cloud . painted surfaces |
Mon, Feb 23, 2015 at 4:13:00 PM
Angular surfaces |
Fri, Oct 16, 2009 at 2:23:30 PM
painted split face doesn't show in dependent view |
Mon, Nov 1, 2010 at 12:32:13 PM
Really Odd Perspective/3D problem |
Wed, Apr 29, 2015 at 7:53:09 AM
Members: | 2000426 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
