73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Flooring Tile setting out
Greetings, (Revit Arch 2013)
I have noticed that when creating a grid ceiling, you can select a line within the grid ceiling and move it left/right/up/down to adjust the setting out (presumably).
Is there a way of doing the same thing with a floor finish? I have set up my floor types so that they show as hatches, conveniently enough I can set a '600sq tile' to appear as a 600sq crosshatch. However the hatch does not start where I want the tiles to start from. Is there a way of adjusting the hatch in the plan view so that it can be taken as a tile setting out drawing? Ie; tiles aligning with walls etc.
Many thanks,
CM.
All 3D material hatches can be modified in a parallel view. That's what they are for.
Thank you but I'm not quite sure what you mean. Could you spell it out please?
Read this section in your HELP:
Model Patterns
Thanks for this, I think this is what I've been looking for, however my floor type does not have a 'shape handle' to select. Is there a way of applying a shape handle to a pattern on a floor type or at least turning it on?
Many thanks.
Any straight line in a pattern can be used - no matter how small.
Hi again,
I have been trying to select a line in my floor pattern in the way both yourself and F1 HELP suggests, but this does not seem to work on the crosshatch pattern I have applied to my floor material or any other pattern, (see attached jpeg and revit model).
I have tried by painting a surface with a pattern and also setting up a material with a surface pattern and then creating it as a floor, it does not work either way. Pressing tab does not select anything other than the entire element, there are no shape handles to select at all.
Any further suggestions?
Right, done a bit more investigating. The problem is that my floor displays a drafting pattern. I need it to display a model pattern in order to edit/align it. So the question is...how can I create a floor which displays a model pattern?
I am using Revit Arch 2013, and two books, Autodesk Revit Arch 2013 N.E.R and Autodesk Revit Arch 2013 Essentials and neither offers an explanation.
Done sorted it thanks you.
Ceramic Tile Flooring |
Wed, Jan 2, 2008 at 9:03:02 AM
Visibility Graphincs |
Wed, Sep 19, 2012 at 8:51:15 AM
Flooring |
Wed, Jun 15, 2005 at 11:22:52 AM
Flooring and Cladding Families |
Wed, Jan 18, 2006 at 5:38:35 PM
Flooring patterns |
Wed, Mar 28, 2012 at 12:44:09 PM
Members: | 1990178 | Objects: | 22877 | Forum Posts: | 152180 | Job Listings: | 3 |
