49 Users Online (47 Members):
Forums >> Community >> Newbies >> Can't rotate object loaded to project
Hi,
I loaded the "kitchen layout" into my project and can't rotate it in plan view...What can be wrong? I exploded the kitche and loaded only some "pieces", maybe that's the rason?
You loaded the Kitchen layout? What do you mean you inserted a CAD dwg? Your question/process is not clear.
Sorry but we don't know what you are talking about.
What is "kitchen layout"? I have no idea.
What do you think you exploded. It must be CAD because you can't "explode" Revit items.
Ok. I found the kitchen cabinets here, on RC, I opened it and loaded into my project . I only needed some part of it, so before loding into my proect I deleted what I didn't need. Thats what meant by "explode". I dont think it matters, anyway. All I want to do is to rotate the cabinest at 90 degree and its not working...
Process is very important and the better you communicate the easier it is to get an answer.
If you are talking about base cabinets and rotating them in plan view, they should rotate in plan just fine.
If you are talking about wall cabinets, I believe they may be hosted and you need a host to rotate them in plan.
If you are tryning to rate in elevation (you don't say) then that is a whole other issue.
Talking about lower cabinets. Still doesn't work, but thanks for help.
Are you trying to rotate them in the project? Your still not giving us enough information. You should be able to just click on the base cabinet and hit the rotate command and rotate however you want. If you cannot it is a problem with the family you have, which you don't tell us anything about. Is the cabinet a floor based family? Like WWHub said if it is wall based family you need to host it to a different wall. Attach the family you have for us to look at. Its either a problem with the family or your process.
All resolved! Thanks for help, I appreciate it.
Having Problem rotating family after it is loaded in the project...(see pic) |
Thu, May 22, 2008 at 2:49:26 AM
No ''materials'' properties on my object |
Fri, Jun 18, 2010 at 11:57:28 AM
Rotate Project North results in 100's of errors. |
Fri, Mar 11, 2011 at 2:33:17 PM
Rotate of family |
Wed, Feb 24, 2010 at 1:32:32 AM
Voids don't work when family is loaded into a project |
Mon, Mar 1, 2010 at 8:13:26 AM
Members: | 1994359 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
