62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Issues with Linked View
Fri, Apr 5, 2013 at 12:53:32 PM | Issues with Linked View
iamian33
iamian33 Avatar
RAC 2013
We have created the following scenario:
Our goal is to use teh Site Model as the one-stop-shop for site stuff. We will link in various files to create our grades and landscape. Some will be printed (like the landscape), others for the creation / development of the topography.
Currently, my site model is linked into the building model. The site model contains a CAD link showing the Landscape design. I have set up a specific view (DP00 SITE) in the Site Model such that the visibility graphics presents the site elements as I want them.
In the Building Model, the visibiliity graphics in the Site Plan view is set to show the building and site model as we want. But when I set Linked View for the Site Model to show the DP00 SITE, elements from the parking level below (in the buiilding model) are now visible through the slab. This is the problem.
We want to see the Site Plan - the topo, landscape and the main floor plan of my building, including the ramp down to the parking below.
As I investigate, I find that if I hide the linked Site Model, the elements from the parking level below also disappear - as if these elements were a part of the site model. When I disable Linked View, everything looks fine, but I loose my landscape design (CAD link in Site Model).
Current Settings for both models
  - All floors are visible and not transparent.
  - View Range settings:
  • TOP=UNLIMITED,
  • CUT= 1200M BOTTOM=ASSOC. LEVEL offset 0
  • VIEW DEPTH= PARKING LEVEL
  • BELOW (unlimited has same result)
Must I link the Landscape design to my Building Model instead?
Ian Shafer
Principal Consultant
True North S&F Consultants
Fri, Apr 5, 2013 at 1:32:09 PM | Issues with Linked View
3.5 Stars: 391 Votes
Why not try the seperate CAD link?
Hidden Object comes back after changing View Template
Wed, Apr 19, 2017 at 12:24:45 PM
Revit MEP 2012 View Port Error with Linked views
Tue, Sep 4, 2012 at 11:50:45 AM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Linked Model Showing In 3D View Only
Tue, Aug 5, 2014 at 1:11:42 PM
Linked files in more than one view
Thu, Sep 22, 2005 at 12:11:19 PM
Page generation time: 0.9932
