147 Users Online (146 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> CMU wall - hatch pattern not showing in plan view
Fri, Mar 1, 2013 at 9:24:08 AM | CMU wall - hatch pattern not showing in plan view
robp72
Hi! I am using Revit Arch. 2013. I cant get my crosshatch to show in my CMU walls in plan view. I created a 2x4 wall with gyp and it hatches.
Thanks,
Rob
Fri, Mar 1, 2013 at 10:16:05 AM | CMU wall - hatch pattern not showing in plan view
3.5 Stars: 391 Votes
Not enough information.
View setting - I assume medium or fine.
View scale ?
How intense is the hatch?
Is the proper hatch assigned to the material in the wall?
Does the view cut the wall?
Fri, Mar 1, 2013 at 1:50:21 PM | CMU wall - hatch pattern not showing in plan view
robp72
Hi! Here is some additional info.: (see attached screen shot)
The view setting (I tried all three coarse, medium, and fine)
The wall is an 8" CMU or block wall (its 25' tall)
The View Range is default Top at 7'6" cut at 4'2"
The hatch is the standard diaginal
The scale of the drawing is 1/8" = 1'
Thanks for your help, I appreciate it.
Take care,
Rob
Fri, Mar 1, 2013 at 1:53:59 PM | CMU wall - hatch pattern not showing in plan view
robp72
I think the hatch isnt showing because the new walls are drawn over an existing CAD file. Is there a way to make the hatch lines come above the CAD line work?
Thanks,
Rob
Edited on: Fri, Mar 1, 2013 at 1:55:08 PM
Fri, Mar 1, 2013 at 1:55:02 PM | CMU wall - hatch pattern not showing in plan view
You are setting a coarse fill pattern.  It will only show in a coarse view - not fine or medium.
Mon, Mar 4, 2013 at 6:13:36 AM | CMU wall - hatch pattern not showing in plan view
robp72
Thanks! I think my issue has to do with drawing a new Revit wall over top of the imported AutoCAD wall. When I draw a new wall in an area without existing walls they work fine.
Take care,
Rob
Mon, Jul 14, 2014 at 2:42:56 PM | CMU wall - hatch pattern not showing in plan view
Ranger57
I changed the View Template from 'none' to 'architectural plan' and all was good.
Wed, Aug 27, 2014 at 2:53:11 PM | CMU wall - hatch pattern not showing in plan view
jajackomo
This issue deals with phase filters. Go to manage, phsaing, and change the phase that you want the material to show up in to by category. In my case, I am showing a plan with existing and new walls but the materials didn't show up in either. I changed the new to by category and now when I specify previous and new in the properties pallete the materials are shown on the new walls by category. You can also apply this to the view template so that when you apply it to view it changes automatically.
Wed, Aug 27, 2014 at 2:57:54 PM | CMU wall - hatch pattern not showing in plan view
jajackomo
Edited on: Wed, Aug 27, 2014 at 4:06:49 PM
CMU Hatch Patern
Sat, Jan 31, 2009 at 4:00:05 AM
CMU Wall
Thu, May 7, 2015 at 12:15:47 PM
What is the best way to hatch a CMU Wall?
Wed, Nov 4, 2009 at 7:00:29 PM
CMU wall reinforcement and detailing
Mon, Nov 22, 2010 at 1:32:03 PM
Fill Pattern/Hatch Pattern are not coherent in different views
Thu, Feb 16, 2012 at 7:20:52 AM
Page generation time: 2.3597
