71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Revit 2013 - visualization issues with ramps
2 Posts No Rating |
Hi everyone!
I am experiencing some problems with ramps.Currently I'm working on a 2-storey villa that has an external ramp. This ramp seem to be invisible as doesn't appear in the plans. And shadows don't work and. The visibility settings are all set in default.
Have you experienced such problem?
Are RAMPS turned on in Visability Graphics? Is it hidden? Does it show up in 3D and section views? Was it created using Ramp or is it an in-place family? Does your view range cut through it?
2 Posts No Rating |
Hi
Ramps are on in visability graphic.
They are not hidden.
They are shown in sections and 3D.
It has been created with the ramp command.
The view range reaches that point.
Basically everything should be fine but in plans are not shown.
Thank you!
ramps presentation [ 1 2 ] |
Thu, Jan 8, 2015 at 8:53:24 AM
17
Attach Walls to Ramps |
Fri, Feb 18, 2011 at 6:45:16 AM
TYPE SELECTOR for ramps and stairs |
Thu, May 3, 2007 at 2:46:53 AM
Showing break lines with Ramps and Stairs |
Mon, Jul 30, 2018 at 11:02:36 AM
Revit 2012 to Revit 2016 - Removing Ghost Surfaces Visualization Effect |
Thu, Mar 31, 2016 at 10:00:40 AM
Members: | 1994890 | Objects: | 22882 | Forum Posts: | 152182 | Job Listings: | 3 |
