85 Users Online (84 Members):
Forums >> Revit Building >> Technical Support >> Cut Adaptive Components
47 Posts No Rating |
Excellent, thanks! I forgot to check 'Cuttable'.
About "Curved Panels": http://buildz.blogspot.pt/2012/05/repeat-and-divide-prt-i-curved-panels.html
HTH
Thanks Typhoon, great video!
1 Posts No Rating |
hey im having the exact same problem with the adaptive components and the repeat command. can you please elaborate further on your solution. its been pissing me off too aha
Hi Cimini,
The solution was that adaptive components that are repeated on a divided surface using the new 'Repeat' tool in Revit Architecture 2013 cannot be cut with a Void object. You can use a 'Curtain Wall based patten' to create the panel and then select the panel from the 'Type Selector' and those panels will repeat automatically and can be cut with a 'Void' object. This didn't suit my project because the surface ended up faceted rather than a smooth curve. If you create a multi-point adaptive component it will follow the contour of a curved divided surface as it repeats but as mentioned will not cut with a Void Object. As a work around, I used a 'Sweep' in a compund wall with a Profile of the shape required to achieve a smooth surface. This was a good work around but inefficient BIM wise in terms of scheduling and work flow as individual elements can't be itemised or replaced but looks looks visually correct.
Check Alfedima & Typhoon's posts in this thread!
Cheers,
Peter
Edited on: Fri, Jan 18, 2013 at 3:51:43 AM
adaptive components |
Fri, Jan 23, 2015 at 7:12:31 AM
annotations on adaptive components? |
Thu, Jan 24, 2013 at 6:21:59 AM
Revit 2012 - Adaptive Components |
Fri, Jul 20, 2012 at 4:28:01 PM
Adaptive component help |
Sun, Oct 7, 2012 at 11:47:47 AM
Can piping be radiused around a duct? |
Thu, Oct 4, 2012 at 10:05:09 AM
Members: | 1989361 | Objects: | 22877 | Forum Posts: | 152179 | Job Listings: | 3 |
