125 Users Online (124 Members):
Forums >> Revit Building >> Technical Support >> Walls in Framing Plan
I am creating a framing plan by cutting the plan at 3" below the floor level. The top of the view range is set at 0 and the bottom is 6" below the floor level. This generally works for me but for some reason parts of a couple of walls are showing up whose bottom is the floor level. Most of all the other walls do not show up. (I can't turn the visibility of walls off because I have a elevator shaft walls I'd like to keep. Thoughts?
Are the walls really at floor level or were they sketched there? Look at their properties and see what level and offset. << May not be the problem - not sure
You can always hide in view individual elements but better to correct the model.
Are the walls in question 'attached' to the floor ? That could come into play. Dettach the wall bottoms if they are in fact attached to the floor. Also like WW said you can turn off the visibility of individual elements as opposed to turning off the entire category. Lastly, try setting the top of the view range to be -1" instead of 0.
I ended up just turing off those individual elements. I'll try some of those other ideas in the future. Thanks for your help!
Framing Plan - Walls |
Mon, Jul 15, 2013 at 7:37:48 AM
wood framing plan |
Wed, Dec 31, 2014 at 9:10:12 PM
Stone Veneer and Framing Plan |
Wed, Nov 14, 2007 at 12:12:22 PM
Walls not showing in plan region |
Mon, Feb 18, 2008 at 1:59:12 PM
14
Framing Plan |
Tue, Jan 3, 2006 at 4:10:28 PM
12
Members: | 1998410 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
