113 Users Online (112 Members):
Forums >> Revit Building >> Technical Support >> Beams connections - "soft", not sharp
4 Posts No Rating |
Hi,
I am wondering, is it possible to set the beams up in a way that they would join like those on the image below? I mean, probably it is (this image shows up when i look for 'revit beams joins bent' in google, nevertheless i have no idea how to model them in revit..i wish they joined softly, not with sharp edges on the joint.
I will be really thankful for help!
(using Revit 2013)
I'm afraid the thing they used on the image is just a wall created on a face of a mass. but maybe someone knows how to do such a thing with beams. I don't need the beams themselves to be bent, only the joints to be "soft"
Edited on: Fri, Dec 7, 2012 at 8:54:33 AM
You are not going to get "beams" to work this way. I would assume that most if not all of the exterior is created using massing. The "trusses" on the interior would most likely be created as a family you would need to create.
4 Posts No Rating |
i'm afraid you're right...
what i need is also visible here : http://static.dezeen.com/uploads/2010/05/dzn_hiding-in-triangles-17.gif
Revit and "connections" |
Mon, Oct 15, 2007 at 12:51:12 PM
How do you change a "generic model" family into a "mechanical equipment" family? |
Fri, Apr 6, 2018 at 6:18:19 PM
rotating "I-Beams" |
Sat, May 6, 2006 at 1:26:49 AM
Structural Beams Questions |
Sat, Sep 8, 2007 at 1:48:33 AM
"Modeling Topos" & Topo's from grade or point?!?! Topo Conceptual Mass? |
Fri, Aug 4, 2017 at 5:52:31 AM
Members: | 2000869 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
