82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> reflective glass on the outside- not reflective on the inside
How can I have my model glazing show clear from the inside so I would see the exterior but yet show reflective when I'm looking at it from outside? Is that possible in Revit?
I don't know - you test this out. Set your glass to reflective, then on one side, paint it as transparent. Paint is a one surface only tool.
Please come back with a view from both sides to let us know.
209 Posts No Rating |
Im assuming when your inside doing a rendering you would not want to see reflection and on the outside you would want to see it. You can create a two panel family for your windows.
One with reflection for outside rendering
One for inside thats transparent.
Use the on/off parameter for both types of panels in the family so you can turn one on and the other off.
That is another possibility.
Solved it The glazing needs to be double pane! yay
Ceilings, walls and columns are reflective |
Fri, May 27, 2016 at 7:59:39 PM
Can you create mirrored walls (shiney reflective ones) with Revit? |
Tue, Nov 25, 2008 at 12:07:26 PM
andersen window issue |
Wed, Aug 16, 2017 at 9:08:12 AM
Rendering Exterior Glazing |
Mon, Feb 20, 2012 at 2:39:01 PM
rendering/ lights |
Sun, Jan 2, 2011 at 6:58:02 PM
Members: | 2000715 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
