66 Users Online (65 Members):
Forums >> Revit Systems >> Technical Support >> curbed wall texture alignment
can anyone help-
i am trying to adjust the texture alignment with MODEL PATTERn on this curved wall- but it wont let me nudge the lines...
the result is a bad seam along the left side...
any ideas??
eli |
Add a straight line wall <same type> element joined to the end of this curved wall. <You may have to pull back the end of the curve to do this.> Then from a view perpindicular to the straight wall, aline - move your pattern, then delete the straight wall.
Doesnt seem to work....
eli |
Try again.
The face of the wall must be at the same plane and the walls must be joined.
Sorry - my method has always worked in the past. It appears that has changed - at least in 12 where I am working now.
Use the "Rotate" tool, here you have an old post: http://revitelemental.blogspot.pt/2010/05/aligning-hatch-patterns-on-curved.html
Railings on a curbed ramp |
Thu, Mar 17, 2005 at 2:50:57 PM
Align texture on In-place component |
Fri, May 23, 2014 at 9:29:28 AM
Help... Applying Rendering Texture to Sloping Wall |
Mon, Dec 8, 2008 at 5:47:54 AM
Texture patterns render black |
Thu, Apr 14, 2011 at 9:14:44 AM
12
different Material/Paint/Texture/Finish to inside and outside faces of the wall |
Tue, Aug 25, 2009 at 3:57:50 PM
Members: | 1992092 | Objects: | 22879 | Forum Posts: | 152183 | Job Listings: | 3 |
