131 Users Online (130 Members):
Forums >> Community >> Newbies >> Room area calculation
67 Posts No Rating |
Thank you for your attention:Let's say I have a bunch of rooms/areas. They fall under 2 categories - room type A and Room type B. I want to create a schedule that will not only list rooms A and rooms B separately, and not only add up the total areas (i.e. total area of all rooms type A and total area of all rooms type B) but also to do a mathematical formula - i.e. Room A total area is multiplied by 1.414 and room B total area multiplied by 1.112. How do I do this in scheduling?I'm ok with calculations, but the problem is that it gets applied to ALL the items listed. I don't know how to do these calculations AFTER they have separated the room types, and each room type has its own formula.Please help!Thank you so much.JLB
Shouldn't be hard.
Keep it simple and create two seperate schedules and 'Filter' each schedule to collect Room A's and Room B's. Then from there you can apply your calculation factor to each schedule seperately as required.
Ley us know if this works.
room area calculation |
Thu, Jan 15, 2009 at 5:51:20 AM
Revit interior walls transmission area calculation |
Tue, Oct 28, 2014 at 1:44:23 PM
Area calculation with dormer |
Mon, Dec 6, 2010 at 8:43:26 AM
Room tags with area - area not showing up! |
Thu, Aug 16, 2007 at 6:54:26 PM
Heat loss calculation formula |
Wed, Apr 29, 2009 at 10:09:09 AM
Members: | 1993083 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
