60 Users Online (60 Members):
Forums >> Revit Structure >> Technical Support >> Spot Elevation Relative to Floor
I have a plan with multiple slab on grade levels and I want to call out top of steel relative to slab(s). Can the elevation origin be set to a reference plane in order to accomplish this?
From your HELP << Always the best place to start.
Elevation Origin If the origin value is set to Project, then the elevation reported is with respect to the project origin. If set to Shared, then the elevation reported is with respect to the shared origin. If the base value is set to Relative, then the elevation reported is with respect to the level in the Relative Base instance parameter. You can change the shared origin by relocating the project. See Relocating and Mirroring a Project.
Changing Elevation Reporting
A spot elevation can report elevations relative to project origin, shared origin, or a specified level.
- Place a spot elevation, and then select it.
- On the Properties palette, click (Edit Type).
- Under Text, specify a value for Elevation Origin. For more information about the values, see Spot Elevation Type Properties.
- If you selected Relative, click OK and, on the Properties palette, select the value for Relative Base.
NOTE _ I do not know if the relative base is one location only. I've not used it this way. and would not.
Thanks - but I want to use multiple "relative" origins - related to the top of slab in each area. Not sure if that is possible.
I really don't understand people who don't even try a simple thing like this before posting. Wow!
I read the help and I read many threads before posting so I think this response will ultimately help future users if they can ignore the attitude.
But - for those of you out there just trying to get a handle on Revit -let me re-explain what I learned today despite the meanness of the responder:
It is possible to change the reference plane of a spot elevation from the default base of "current level" to any level you have created BUT
1. If the spot elevation parameter called "elevation origin" is either "shared" or "project", you need to change it to "relative".
2. There is a constraint parameter called "relative base" that will look like it is greyed out until you hit the OK button. (Not just the "Apply" button.)
3. AFTER you hit OK, you can change that parameter for "relative base".
It is the hitting of the OK button that is critical to the process, otherwise you will just think you have done nothing.
Glad to see you finally tried it. You will find that hands on experience will get you farther than hand holding.
1 Posts No Rating |
@ndb110 Your explanation helped me 'make it work' THANK YOU!
Elevation marks relative to plan zero elevation |
Wed, Oct 17, 2007 at 1:34:16 PM
Controlling Relative Spot Elevations |
Tue, May 17, 2011 at 1:30:07 PM
more complex spot elevations |
Tue, Jan 23, 2018 at 7:48:21 AM
Spot elevation and "current level" |
Fri, Feb 17, 2017 at 3:11:01 AM
Toposurface is drawn at the wrong elevation relative to levels |
Fri, Aug 4, 2017 at 12:09:48 PM
Members: | 1994450 | Objects: | 22882 | Forum Posts: | 152186 | Job Listings: | 3 |
