45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> Render list of views
Search this ThreadSearch this Thread | Page 6 of 7 | << Previous 3 | 4 | 5 | 6 | 7 Next >>
Wed, Jul 16, 2014 at 1:55:39 AM | Render list of views
#76
RVANL
Here are the screenshots as reguested. I'm using an English version of 2014.
I just tried it again at Draft settings and your addin is saving the renders as it should. (Allthough the short filenames are appearing in the dialogs) Strange.
Wed, Jul 16, 2014 at 2:08:47 AM | Render list of views
#77
frifer
5 Stars: 4 Votes
thanks, your help is very useful to find the problem.
can you please try if it works when you uncheck "save to project"? i think that this is the module that is causing problems.
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Wed, Jul 16, 2014 at 2:18:48 AM | Render list of views
#78
RVANL
I'll try again around lunch time....
Wed, Jul 16, 2014 at 2:23:21 AM | Render list of views
#79
frifer
5 Stars: 4 Votes
thats fine! i would also need another screenshot when you ahve time please:
run the rendering without the plugin, when it is done, do not close the render window, select the render settings window with the mouse and press SHIFT + X.
after pressing shift + x a window should open (the same you posted a few posts ago..) please send me a screenshot of that situation.
But plaese do it by pressing SHIFT + X and not with the mouse.
thanks!
take your time!
Wed, Jul 16, 2014 at 2:28:21 AM | Render list of views
#80
RVANL
When I hit Shift+X the save image dialog appears. (As it should I presume?)
Edited on: Wed, Jul 16, 2014 at 2:33:33 AM
Wed, Jul 16, 2014 at 2:40:12 AM | Render list of views
#81
frifer
5 Stars: 4 Votes
yes thats fine.. is the textbox empty?
Wed, Jul 16, 2014 at 3:17:00 AM | Render list of views
#82
RVANL
Not empty...see screenshot.
Wed, Jul 16, 2014 at 3:47:50 AM | Render list of views
#83
frifer
5 Stars: 4 Votes
sorry my fault.. its SHIFT+V
Thu, Jul 17, 2014 at 2:24:58 AM | Render list of views
#84
RVANL
It's not empty... See screenshot. Should it be?
Thu, Aug 14, 2014 at 1:10:24 AM | Render list of views
#85
RVANL
Last night I retried to render 11 views. This morning only a part of the first view was rendered.
The region selection box was checked so only a small part of my view was rendered and the processbar showed 100%. The autoclose checkbox was not checked so it was waiting for me.
Can you fix this?
See screenshot
Wed, Sep 17, 2014 at 4:14:36 PM | Render list of views
#86
eljefeutexas
try changing the name of your views, the -3D- part is incorrect. You cannot save files in windows with a dash. Change it to 3D.
Sat, Feb 21, 2015 at 2:25:04 AM | Render list of views
#87
vrgdaniel
hi there one question i really like yuor script , but the problem is i never used apps for revit and i dont know how to make the external tools button apper, i dont have it on my add in tab . i installed one addin like 5 min ago, so to see if at least one randmod addin works
and it does , but i still cant get the external tool or make the batch render scrit button to show
im using win 7 64 bits , instaled net frame work 4.51 put the file in C and the addin  file in revit , even if my directory path to revit  is diferent its program file autodesk revit 2015 addins
so can yolu please help me, how do i get the external tools button to show up , i need to make like 50 renders and its imposible to achive whitout a batch like yuors, thx
Fri, May 8, 2015 at 4:08:41 PM | Render list of views
#88
apsis
Do you have the code for This? I would love to take a stab at it.
Mine is not working either. I updated the addin go to a subfolder for the DLLs- open the pulldown and nothing happens.
You can email me direct with a reply(It goes to mey email)
Thnx!
Ron
Fri, Oct 30, 2015 at 4:49:35 AM | Render list of views
#89
frifer
5 Stars: 4 Votes
Hi all!
Updated the addin for the 2016 version.
enjoy
Wed, Aug 31, 2016 at 9:29:22 AM | Render list of views
#90
CamLRiou
Igor would you be able to update your script for revit 2017
thanks
Render List of Views 2017
Wed, Apr 5, 2017 at 10:17:53 AM
Elements Missing in Render Image
Mon, Sep 27, 2010 at 7:21:17 AM
Drawing list gone
Thu, Nov 1, 2012 at 1:57:58 PM
can't find the render button
Mon, Nov 15, 2010 at 12:15:12 PM
2013 Graphics card driver list
Tue, May 8, 2012 at 9:29:58 AM
Page generation time: 8.6478
