Forums >> Revit Building >> Technical Support >> lin weight on walls
Wed, Jan 11, 2006 at 12:21:44 PM | lin weight on walls
hammer87
hammer87 Avatar
3 Stars: 4 Votes
when drawing lines on walls, is the a way to draken the lines so they show up better?
Wed, Jan 11, 2006 at 5:53:14 PM | RE: lin weight on walls
eldados
eldados Avatar
4.5 Stars: 8 Votes
are you talking just the view on your screen or printing? to see the lines thicker you can use the "thin line" button on top. or you can adjust your object style settings and assign a thicker pen to your walls: from the top menu setting--> object style... HTH
Integrator
KarelCAD
Surface Pattern Line weight of walls
Wed, Nov 4, 2009 at 4:22:31 PM
changing property line weight in Revit 2009
Thu, Jun 18, 2009 at 12:58:52 PM
Perspective line weight
Sun, May 3, 2009 at 9:53:35 AM
Elevations line weight
Mon, Feb 4, 2008 at 9:03:42 AM
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:23 AM
Page generation time: 0.5524
