68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Materials dissapear
4 Posts No Rating |
not sure if this is the right place to post but. i have added materials to models and they show up fine, but for some reason the current model i am working on the materials only appear in the edit model , once i close the edit model they , well you know , go away.
is something turned off to allow this, Thanks in advance.
Edited on: Thu, Sep 6, 2012 at 10:55:55 AM
your question is kinda vague. Could you provide some screen shots illustrating your issue?
4 Posts No Rating |
Attached are 2 images 1 is with the materials dialog closed # 2 shows with the materials still in edit mode. Again once i close the dialog it appears as # 1
Thanks again
209 Posts No Rating |
do you have elements that are on a previous phase? If so set the view to show complete.
4 Posts No Rating |
Yes that seems to have been it although I needed to set it to show complete in the filter. I guess it ll be a little tricky since we are refacing the counter ( existing ) with a new laminate
thanks Much!
Are you using the material default path?
Motto: "No Post left behind" |
4 Posts No Rating |
It was the phasing setting, but thanks anyway!
Merging Toposurfaces |
Tue, Apr 21, 2015 at 7:45:50 AM
crop regions and text |
Wed, Sep 28, 2005 at 10:25:26 PM
Adding materials into Revit's materials files |
Thu, Jul 22, 2010 at 1:54:48 PM
Missing Materials |
Wed, Jun 19, 2013 at 2:22:26 PM
Converting DWG materials to Revit Materials |
Thu, Sep 13, 2012 at 3:50:29 AM
Members: | 2000584 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
