77 Users Online (76 Members):
Forums >> Revit Structure >> Technical Support >> Problem with Levels and Plans
I copy/monitored the architects levels (probably a mistake) and kept revits level 1. I aligned revits level 1 to the first floor level of the architects.
Ok - this is where I am having problems.
The architects does not show up as floor plans. And if I add a level, say BMD, it does not show up as a floor plan either. How do I get the new levels I add to make a corresponding floor plan?
Yeesh - Where is My Cad
Yeesh - Where is My Cad |
First, I think you should use all of the levels and grids from the architects model and delete your original. Having identical levels will go a long way to stop confusion and problems when the architect tries to use your model.
I WILL ADD - Don't move anything from your linked model! Now you will not have problems with origins.
Levels do not come with associated plans, you have to create those. To create plans from levels, simply goto the view tab - pick floor plan and pick your levels.
Edited on: Wed, Sep 5, 2012 at 2:20:35 PM
OMG!!!
Thank you - I am just so use to Revit automatically putting them in. This is the first time I am trying to copy/monitor (C/M).
Do you know why Revit will put a corresponding floor in when I add a level on a job that I am not C/M but not on one I am C/M?
Revit essential asks you when you create a level. Look at the options bar - check box. Obviously CM levels is not the same process.
Another "OMG" (on the options bar)
Thank you!
Senior Cad, I think it is time to take the Yeesh wheres my Cad off your salutation.
Really!
If you have time to comment on my "Yeesh - Where is My Cad"
then can you take time to figure out my problem in this thread
"Before I Start Copy/Monitor"
http://www.revitcity.com/forums.php?action=viewthread&thread_id=28313
Converting associated levels to non plan view level |
Fri, May 31, 2013 at 12:37:05 PM
Phaseing Levels |
Fri, Oct 15, 2010 at 6:23:50 AM
level not show up on plans |
Tue, Feb 28, 2006 at 4:15:15 AM
Elevations and plans all messed up |
Mon, Dec 16, 2013 at 1:50:42 PM
How do you Delete levels without deleting everything associated to them??? |
Tue, Jan 24, 2012 at 8:17:42 AM
Members: | 1992091 | Objects: | 22880 | Forum Posts: | 152184 | Job Listings: | 3 |
