37 Users Online (36 Members):
Forums >> Community >> The Studio >> Residential BIM model
1 Posts No Rating |
I am an architecture professor looking for a BIM model of a residential house for academic use......would anyone know where i could get one?
Thanks
Michael
sorry mate, I don't do residential...
you could put a simple house together very quickly though. can you use Revit?
Same here...don't do residential. If you are an instructor teaching Revit you might be able to get a sample house through Autodesk.
Tom
2 Posts No Rating |
there is an excellent book on Residential using Revit:
"Residential Design Using Revit Building 8" by Daniel John Stine
worth to get it...give it a try you might end up having your residential model!
Hope that helps,
Kal
I'm an instuctor certified with the State of Wisoonsin. Consider going to this page to get Revit courseware with datasets that you can use in your classroom. While this CD is availabe to instructors in the US/Canada, there is an email address to contact an educational dealer in your country.
Check out the listings on the left side of the screen on this page for additional courseware and datasets that you can download and might meet your needs.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4356896
If you have Revit, there are tutorials that ship with the product that you can access through the HELP pulldown menu. There are a few residential models included that would eliminate starting from scratch. If you don't have Revit, you can download and install a trial version from the Autodesk website.
Cheers to higher learning!
Revit Blogs:
www.taylor-tech.com/danielhughes
http://www.cadgrafx.com/blog/revit/
LinkedIn Profile:
- http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com |
Why Revit for BIM on Residential homes |
Fri, Jan 13, 2017 at 12:42:17 AM
elevator BIM model |
Fri, Sep 14, 2012 at 4:04:11 AM
How to model residential garage slab on grade with slope and stem walls |
Thu, Oct 10, 2013 at 3:30:52 PM
MS project plan connectivity in REVIT for BIM model |
Wed, Sep 3, 2014 at 3:36:55 AM
BIM 360 Link Issues |
Wed, Sep 12, 2018 at 12:10:50 PM
Members: | 1977372 | Objects: | 22860 | Forum Posts: | 152166 | Job Listings: | 3 |
