139 Users Online (138 Members):
Forums >> Revit Building >> Technical Support >> Spot Levels
65 Posts No Rating |
You can put an spot level on an horizontal detail line inside your section view. Then you select the detail line so the level text turn blue and with this you will be able to type the exact level you want for your stair... hope it works for you.
ahh what a relief. At last I got the solution. Thank you very much guys, both of you. Both methods work. A huge hug for you.
7 Posts No Rating |
Hello,
I have a project that I have linked in floor plans. I Cannot put spot levels on the slabs?
I have a simular Project again with Links and I have no problem putting spot levels on the slabs.
I have checked that the slabs are turned on in the views and I can put Spot levels on in 3D views and in Section Views, but not plans.
I have also linked in the plans that are not working in this file into the file where I have no problems and I can Spot level the slabs there.
Is there a setting somewhare causing this issue? I am stumped.
Check if the view is in 'Wireframe' mode.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
Spot levels on external floor family |
Fri, Aug 17, 2007 at 2:44:13 AM
Spot elevations text on angle |
Thu, Oct 18, 2012 at 9:08:09 AM
Spot Elevation vs. Level elevation |
Wed, Feb 14, 2018 at 6:13:20 PM
Adding 100' to Spot Elevation |
Tue, Jan 31, 2012 at 10:36:28 AM
Setting a manual height for Spot Elevations in plan |
Wed, May 27, 2015 at 8:03:11 AM
Members: | 2004189 | Objects: | 22887 | Forum Posts: | 152177 | Job Listings: | 3 |
