48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Duplicate material still changes original in Revit Architecture 2013
Mon, Jun 11, 2012 at 2:08:12 PM | Duplicate material still changes original in Revit Architecture 2013
#16
3.5 Stars: 390 Votes
Ah, I thought you just wanted to duplicate a material to assign a different asset or to assign a new one that you created.  Obviously changing the base does affect all materials that use that definition.
Glad you discovered this on your own.
Tue, Oct 30, 2012 at 6:30:30 PM | Duplicate material still changes original in Revit Architecture 2013
#17
apougat
thank you for the thread.. i actually had the same problem trying to figure out for like an hour how to duplicate the material without ahving the original screw up.. this is one of the things in revit thats complicating for no reason
Sat, Dec 8, 2012 at 4:50:05 PM | Duplicate material still changes original in Revit Architecture 2013
#18
mcrhea
thank you for posting this!! my original kept changing.ive been trying to figure it out.
Thu, May 2, 2013 at 5:07:49 PM | Duplicate material still changes original in Revit Architecture 2013
#19
sroreilly
Oh my goodness. Who would have known THAT??? Thanks for posting. I've had the same issue.
Fri, May 3, 2013 at 6:09:29 AM | Duplicate material still changes original in Revit Architecture 2013
#20
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
I was about to say the same thing. You have to change the asset names as well, otherwise different materials read from the same assets.
Fri, Sep 27, 2013 at 9:21:39 PM | Duplicate material still changes original in Revit Architecture 2013
#21
Hug8horn
Assuming it's a default Revit material your're trying to modify, you can also add it to the project again from the materials list and  rather than replace the existing one, choose to keep each separate. This automatically creates duplicate assets.
Sat, Sep 28, 2013 at 11:08:42 AM | Duplicate material still changes original in Revit Architecture 2013
#22
mneglia
The problem is that when you duplicate a material in version 2013, the render appearance is not duplicated. You must change the render appearnce seperatly for any dupliacte materials. Not sure who thought this was a great idea.
Revit blog: www.bimeveryday.com
Thu, Mar 20, 2014 at 4:52:46 AM | Duplicate material still changes original in Revit Architecture 2013
#23
Thommynat0r
in revit 2014 u can duplicate the material, rename it and change it with "Replaces this Asset" (u have to create there a favourite)
Thu, Jan 21, 2016 at 12:01:28 PM | Duplicate material still changes original in Revit Architecture 2013
#24
MrMusky1969
Thread #13 is the answer here. Thanks Nicole!
Thu, Jan 21, 2016 at 12:03:10 PM | Duplicate material still changes original in Revit Architecture 2013
#25
MrMusky1969
Oops, meant #15
Material troubles when duplicating a material
Mon, Dec 12, 2016 at 8:47:07 PM
Revit 2013 Material Creation
Fri, Mar 15, 2013 at 3:35:40 PM
Revit Arch. 2013 - Material Take-offs on specific areas
Thu, Mar 7, 2013 at 8:23:26 AM
2013 Revit Materials
Mon, Oct 8, 2012 at 8:43:00 AM
Material Editor 2013 w/ Update Release 2
Fri, May 2, 2014 at 9:28:04 AM
Page generation time: 1.8303
