32 Users Online (31 Members):
Forums >> Revit Building >> Technical Support >> Strange wall join problem
6 Posts No Rating |
When i try to connect two walls in a corner, they refuse to connect correctly.
The wall types are the same. I don't know why revit insists on breaking up the wall in two parts (see attachement).
I the walls look normal when not connected, only when i extend one side so it overlaps with the other side,
revit constructs this ??
Are these stacked walls?
Are both walls the same height with the same base point?
6 Posts No Rating |
Base point is the same: Base constraint: Level 2, offset 0
Top constraint: up to level 3
How can i see if it is a "stacked" wall ? Although i guess not.
If these two walls are the same and these have the same height and base point, then there is something else here that you have not shared with us. Something else is cutting this wall.
Keep looking
6 Posts No Rating |
It seems to be the corner. I can't create any joined wall on this corner (tried other types/standard types). Don't know why.
6 Posts No Rating |
mmm...anytime i create a will on the right edge, i get the following error message (see screen capture).
note: the walls on the top edge and in the middle are all ok,
6 Posts No Rating |
Very strange. When clicking the error message, i discovered that there was still a small wall present (half hight) on level 2.
This wall was not visible in any of my views, except the "Site" view ???
When i deleted this wall, the problems went away....
Over time, you will learn to trust the program and recognize that if you have a problem, you created it - somehow. Glad you found the problem.
90degree wall join |
Sun, Aug 20, 2006 at 9:08:54 PM
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View |
Tue, Jul 22, 2008 at 9:38:24 AM
Clean wall join |
Sat, Apr 20, 2013 at 3:30:48 AM
11
HELP!!! STRANGE WALL PROBLEM!!! |
Mon, Dec 3, 2012 at 7:07:44 AM
join geometry problem |
Wed, Jan 27, 2010 at 5:53:31 AM
Members: | 2000467 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
