77 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> Masking region hierarchy
And I thought I was the one always pointing to the Help....
This information was not available in earlier releases and I had not seen it.
Good pointer jmgrsq - It looks like I have some tools I was not using.
0 Posts No Rating |
I was having the exact same issue with tables and chairs, and found this entry
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-317442EB-D50B-4BE6-B0F8-1F3BE3AB74B9
just wanted to post since the link from jmgrsq is broken
For the chair family, if you turn OFF "draw in foreground" and have the masking region set to a reference plane at the proper height is shows up properly - I had two separate masking regions, one at the elevation of the seat and the other at the height of the seat back. I also set the table masking region to a reference plane at the proper height.
Edited on: Fri, Aug 14, 2015 at 11:31:51 AM
Edited on: Fri, Aug 14, 2015 at 11:32:16 AM
0 Posts No Rating |
A=stool
B=sofa
select A=stool family.
go to edit family.
change the view to front elevation.
add model line <invisible> which must heiger than your B=sofa height.
have you tried using these? (image)
Masking Region Fill Region Problem |
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region at section callout head. |
Tue, Jul 30, 2013 at 1:43:26 PM
3D CAD import Part and masking region |
Sun, Sep 14, 2014 at 2:36:26 PM
Masking region in roof plan |
Tue, Feb 24, 2009 at 3:14:03 PM
Masking Region doesn't seem to be masking |
Thu, Mar 17, 2016 at 10:59:36 AM
Members: | 2000315 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
