79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> Sloped curved wall - brick pattern tapers with the wall...help!
2 Posts No Rating |
I've got a curved wall that tapers down that I modeled in place and created using a blended sweep. I then applied a brick material to the blended sweep that is the same as the brick material used on all of my other walls in the project. As you can see in the image attached, the pattern is angled and tapers down with the wall...it's not just an issue of looking at it in 3D, it looks the same in an elevation view. I've tried removing the material and using the paint tool and it has the same results. Does anyone have a quick solution to this? I have several walls in the project like this...
Thanks!
Edited on: Thu, May 17, 2012 at 10:45:09 AM
Model a normal wall of uniform height, with the curve in plan. Then, make a void swept blend, to be cut from the normal wall.
Planta1 Revit Online Consulting | info@planta1.com |
Normally, if this was just a curved wall with a void cut like alfmedina says, you could add a straight section of wall with brick and join the two. Then rotate the pattern on the straight section, then delete the straight section. This might work with this face applied pattern ... but I'm not sure.
You might also try just assigning the brick to your sweep rather than face painting it. In either case, make sure this wall is in the wall category.
This is the result, when the wall is done with the method described above, and with materials by layers, not paint.
2 Posts No Rating |
Thanks for the help! Cutting with a void worked perfect.
Brick Pattern on In-Place-Mass is Lignter than on Wall |
Sat, Mar 19, 2016 at 11:31:56 PM
Sloped Curved Wall & Cutting Wall |
Tue, Sep 30, 2014 at 7:01:36 AM
Revit 2015, Curved Wall Sweep Model Surface Pattern Inconsistant |
Tue, Apr 28, 2015 at 4:09:13 PM
brick sill below window on brick wall |
Thu, Mar 13, 2008 at 6:10:23 PM
Creating a Curved Sloped Curtain Wall |
Fri, Jul 9, 2010 at 2:20:03 AM
Members: | 1998879 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
