57 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Convert Revit to Autocad 2011
1 Posts No Rating |
I do not know Revit, but it is taking my coworker three or 4 hours to convert at revit file to CAD?
Are there any shortcuts?
is getting a new coworker an option?
"converting" Revit to AutoCAD involves simply Exporting the Revit file to an AutoCAD format. That process itself is not very difficult and time consuming but there may be other factors involved in your case that your coworker is struggling with.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture |
It does take a long time to export Revit files to CAD. Especially if the computer is not good or the files are very heavy. It is also very stressful.
11 Posts No Rating |
I have found that if I make a AutoCADD "sandbox" file works well.
I will take an exported view, say a floor plan.
Keep the layer names as assigned in Revit.
Revise the colors to match office standard. (we use colors to control line weights) Run a check plot. If OK save file as "Revit Transfer.dwg".
Now when I exprot file from revit, I will wblock the file into this new sandbox file. It will force the layers to comply with our plotting standard. As fas as changing layer names, forget it and move on.
2D DWG Convert to 2D Revit |
Mon, Nov 23, 2015 at 1:57:38 PM
How 2 convert more number of Revit (*.rvt) to AutoCAD(*.dwg) files @ a time |
Fri, Aug 28, 2009 at 6:40:58 AM
CONVERT RHINO TO REVIT |
Thu, Feb 13, 2020 at 5:10:11 AM
Default how to convert autocad blocks (inserts) into components (family instan |
Fri, Nov 9, 2007 at 5:12:51 PM
To convert autocad x,y,z points into a site din revit project |
Tue, Nov 29, 2005 at 3:05:11 AM
Members: | 1993978 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
