Forums >> Revit Building >> Technical Support >> open Revit 2013 file in Revit 2012 ?
4 Posts No Rating |
Hello,
Is it possible to open a reivt 2013 file in Revit 2012?
I had to reinstall Revit 2012 because Revit 2013 was very slow and crashed a lot of times. But now I have to start all over again. Any ideas?
Another question:
Where would you model the urban context, (city model)? In the project file or as a separate family or a conceptual mass which is linked to my project?
thx
Phil
Hello,
No, never have and never will. atleast not from Autodesk
4 Posts No Rating |
ok thanks for the quick response.
And what about the urban / city model? As a sperate family, conceptual mass or within in my project.
It is possible to link a dwg in conceptual mass or family? or only embedded?
"Where would you model the urban context, (city model)? In the project file or as a separate family or a conceptual mass which is linked to my project? "
I would do this in either another project or as a conceptual mass and link it into your project. Doing it as a mass would probably be the easiest.
Yes you can import CAD into a MASS
4 Posts No Rating |
thx again!
no possiblity to link the dwg?
huhh revit is really not a pro-active program
4 Posts No Rating |
Ok. One last question
When I load the conceptual mass into my project the masses are transparent! Why?
that's just the material qualities assigned to mass. you can change that in the material options.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture |
"that's just the material qualities assigned to mass."
You can also add walls to the mass by using the wall by face tool.
"auto" open in Revit 2012, when you have both 2012 and 2013 |
Sun, Jul 12, 2015 at 4:52:17 PM
Revit 2013: not enough memory to open project |
Tue, Jun 12, 2012 at 1:41:26 AM
REVIT 2013 |
Wed, Feb 6, 2013 at 12:06:48 PM
Opening new files open new instances of Revit 2012 |
Fri, Sep 23, 2011 at 12:45:01 PM
Going from a Revit 2012 file to an older version of Revit |
Thu, May 26, 2011 at 12:29:18 PM
