146 Users Online (145 Members):
Forums >> Revit Building >> Technical Support >> Can a Yes/No Parameter control a Length Parameter?
21 Posts No Rating |
I'm constructing a window family which I want to behave in the following manner: A yes/no parameter called "brick veneer". When this is checked, I wish the Length parameter "Interior Sill" to be 50mm. When the box is unchecked, the length parameter reduces to 0mm. Any suggestions?
Someone may know how to do this easier, but I would make two elements in the family. Have a yes/no parameter as you mentioned and the 50mm interior length is set for visability to be ON if YES and OFF if NO. Then the other element with a 0 length would be opposite (OFF if YES, ON if NO).
**Using Revit Architecture 2009, 2011, and 2012** |
Yes. The formula for the length parameter would be if(brick veneer, 50, 0).
well done, Tkennedy.
Worked like a charm... I knew a formula would do the trick (just not proficient enough to figure it out myself).Thanks Lizard
Sorry... *TKennedy
-ve value for a length parameter |
Thu, Dec 2, 2010 at 12:14:32 AM
Length Parameter |
Mon, Mar 17, 2008 at 10:44:55 AM
Instance Parameter connected to a Visibility Parameter for Scheduling Purposes |
Wed, Mar 7, 2012 at 5:53:46 PM
'Inconsistent units" error in parameter formula; length vs integer |
Fri, Dec 13, 2013 at 10:37:04 PM
Changing the value of a Length parameter based on the value of a Yes/No paramete |
Fri, Apr 10, 2009 at 11:37:50 AM
Members: | 1998955 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
