41 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Modify Door Tags from a revit liked file
5 Posts No Rating |
I really need help here figuring this out, if there is even a way. We deal with modular construction and therefore we multiply alot of our modules therefore we usually create one and then link it in a project to save time. At the moment we can not figure how to modify the door tags, we can insert them rotate them but we can not change the numbers. Is there a way to change them? Binding the links is not going to happen and trust me it is worth to link all those files. Thank you in advace for any help you can give even if its telling it can not be done at least I will not waste my time anymore.
You have to edit the linked file to change element properties in it.. The easiest might be to do it from a working schedule in that file.
If this is multiple links of the same file, then obviously, the above will not work. Then I would create a fake door family that you place in your model that is tagable...... just an invisible line family in the door category and then don't tag the linked model.
Edited on: Tue, Mar 13, 2012 at 9:08:29 AM
5 Posts No Rating |
The only problem I see with that is, dont I need a Wall to insert the Fake door in??
5 Posts No Rating |
What other family could I use to have the same tag as a Door?? And I really do Appreciate your help
Here is an invisible door family that will tag and schedule and is non-hosted. Set up multiple types if needed for your schedule. Then place these where your doors are - they will tag automatically so start in the #1 location and move sequentually from there.
5 Posts No Rating |
WOW!! I made my own from a generic model base family but your is 1000x better, I can not thank you enough. Thank you, you saved us hours of work.
This was just a few minutes.... Generic template (non-hosted) - changed category to door and put an invisible line circle in it. Pretty simple.
BTW - Invisible families like this can get lost in your project because they are invisible. Of course you could find them with a schedule but here is something you might want to add to this family.
- Open the family in the family editor
- Goto the object styles and create a new model sub category (linetype) I name it something like HIDE THIS
- Add an X or O in using this linetype in your family plan view
- save and load the family
Now set up your plan templates in the project to not show this sub-category under doors. Just turn it on when you really want to see them.
We use invisible families like this for many types of things.....
55 Posts No Rating |
I just found this problem in my current project.. Thank you nasab5 and WWHub for the solution
Transfering door and window tags to Sheet File |
Tue, May 8, 2007 at 2:13:35 AM
Can I export a 3D revit file(fbx,obj,etc) with annotations(door/window tags)? |
Thu, Oct 1, 2020 at 2:35:40 AM
More On Tags |
Fri, Feb 3, 2012 at 9:06:59 AM
Modifying the default tags |
Thu, Jul 3, 2008 at 11:30:18 AM
Door Tags |
Mon, May 12, 2014 at 8:31:35 AM
Members: | 1991686 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
