Forums >> Revit Building >> Technical Support >> snub wall
Fri, Dec 16, 2005 at 7:49:25 AM | snub wall
framerman
4 Stars: 13 Votes
I have these two walls meeting at a 45º inside corner. I'd like to snub the end so I have a 3½" face on the end of the horizontal wall. I attached a drawing to illustrate. Is there a quick fix for this?
Fri, Dec 16, 2005 at 12:11:27 PM | RE: snub wall
TomDorner
4.5 Stars: 25 Votes
You want to use the "Edit wall joins" tool, choose "square" and cycle throught the choices. See the Revit help file for more info. HTH Tom Post edited on 2005-12-16 12:12:24
Fri, Dec 16, 2005 at 8:15:12 PM | RE: snub wall
framerman
4 Stars: 13 Votes
Great! Thank you, it was exactly what I was looking for.
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
create a wall sweep on an angled wall (gable end wall) (2017)
Wed, Aug 3, 2016 at 2:29:53 PM
wall mounted toilet wall error
Wed, May 6, 2009 at 3:41:37 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
Arched Opening in a Curved Wall [ 1 2 ]
Thu, Nov 15, 2012 at 12:32:31 PM
17
Page generation time: 1.3007
