72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Rendering and Number of Cores
I built a computer with 2 x5355 dual Xeon processors at 2.66 GHz each and 4 cores each for a total of 8 cores. I installed Windows XP Professional x64. I have 32 GB ram and an Nvidia FX5800 graphics card (their high end card) with 8 GB ram on board. I have a 102 Meg REVIT 2012 drawing and rendering the inside (office bldg) on a high rendering it is taking as much as 18-20 hours to do a good quality rendering. It does well when maneuvering, editing and multi tasking energy and structural analysis with Revit running at same time BUT….
I think the key is the number of CORES one has, therefore a rack system with about 3-4 computers chained together with as much as 32 cores ( 4 computers @ 8 cores each) with the same FX5800 to drive my dual monitors at 2580x1900 each sounds like it will do the job. At this point I don't care, I'll build what I need I just need some direction and experience from those of you out there who might provide some more information.
Anyone out there can expand upon this and provide some insight?
yeah if your spending that high dollar on a system for Revit rendering you are wasting time and money. Get 3ds Max and use your machine to its full potential if render time is crucial
Fill me in on 3DMax? Why is it so good? How will it save me on rendering time when I am usign the same hardware. Is it how the code is written versus Revits rendering engine? What?
I saw 3dMax in use at another office and it seems convoluted and hard to learn........... or is it?
Thanks in Advance
I don't find rendering and navigating in 3ds max that difficult. The material editor is far superior, you are able to render on that badass Quadro 5800+8 cpu cores using iRay. It gives you more functionality over photometric lighting and animation control. Its built for rendering, if rendering is a large part of your business and the main reason you built a high power workstation you will definitely be better off.
Thanks I'll look into 3DsMax. SOunds like it works a different rendering engine than standone Revit. In so far as being cost effective it sounds like an upgrade to 3dsMax is far cheaper than hardware.
if you have the Autodesk Suite, then you already have 3Ds Max Design which should mean your needs.
BTDT I dont
the suite is pretty sweet.
Rendering on 2 cores.... wait... make that one |
Fri, Oct 9, 2009 at 4:38:16 PM
New system, need CPU help |
Thu, May 13, 2010 at 10:32:06 PM
Will Revit and autoCAD 2012 and newer use more than 4 cores for 3d draftnig? |
Tue, Jun 26, 2012 at 11:13:35 PM
Number of Cores / Threads revit supports |
Tue, Aug 19, 2014 at 8:50:56 AM
limiting core usage of the rendering engine??? |
Wed, Feb 27, 2013 at 7:49:44 AM
Members: | 2000305 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
