59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Families with multiple Options
Fri, Jan 27, 2012 at 11:04:37 AM | Families with multiple Options
#16
TKennedy
4 Stars: 7 Votes
It sounds like you are using the parameter the user interacts with (User Control in my examples) to control the Y/N parameters. That is wrong. The User Control parameter only controls the Parameter Control parameter, which then controls your Y/N parameters.
If you can get your family attached to this thread, we could take a look at it directly.
Fri, Jan 27, 2012 at 11:15:17 AM | Families with multiple Options
#17
designimpressions
Hi mhans,
Thanks for the link, I have captured the screen ok. When I choose the file and submit the tread the image doesn't attach. I would have expected an upload button after the file is choosen but there isn't one so I presumed the image attached automatically.
Thanks,
Peter
Fri, Jan 27, 2012 at 11:33:05 AM | Families with multiple Options
#18
designimpressions
Hi Tkennedy,
Yes that is some thing I got working, I did it slightly differently though:
Y/N1                Choose Option < 2
Y/N2                Choose Option = 2
Y/N3                Choose Option > 2
Choose Option 1
( Choose Option 1 is the User Parameter)
This worked fine thanks to Klaus Munkholm, I wouldn't like to take the creditSmile
Thanks,
Peter
Fri, Jan 27, 2012 at 12:05:52 PM | Families with multiple Options
#19
designimpressions
Hi Tkennedy,
That's exactly where I was going wrong, I was using the User Control in the formula instead of the Control Parameter. It works perfectly well now.
Thanks,
Peter
Fri, Jan 27, 2012 at 12:23:38 PM | Families with multiple Options
#20
mhans
3 Stars: 10 Votes
Guys,
Once you are done here, can you re-post this thread with the Subject: Workarounds: Families with Multiple Options. (Or whatever title suits you.) Suggested format would be:
Problem: (This is your original problem.)
Workaround: (The final/best solution.)
I am campaining that all "Workarounds" will be easy to find. Tnx.
Motto: "No Post left behind"
Fri, Jan 27, 2012 at 2:58:22 PM | Families with multiple Options
#21
designimpressions
Hi Mhans,
Where do I re-post ther tread?
Cheers,
Peter
Fri, Jan 27, 2012 at 3:43:12 PM | Families with multiple Options
#22
mhans
3 Stars: 10 Votes
For now, please re-post them under Tips & Tricks. This will surely help compile all "Workarounds" in a touch of a search. Tnx.
Sat, Jan 28, 2012 at 5:20:10 AM | Families with multiple Options
#23
mcantwell
mcantwell Avatar
Re image files not attaching
For me the web browser affected attaching images. Windows explorer works but Opera or Firefox, forget which, failed to attach. (a while ago at least)
Thu, Feb 4, 2016 at 12:52:03 AM | Families with multiple Options
#24
fredw2357
Had the same problem with ends of hold down bolts.  I used yes/No Parameter in logic statments.  See Screen shot.
Thanks for the ideas.
Grouping multiple families types with multiple options
Mon, Jun 11, 2012 at 3:50:19 PM
Multiple Design Options in One View
Tue, Apr 15, 2014 at 1:20:58 PM
Multiple design options - glitch?
Fri, May 23, 2014 at 9:24:32 AM
Using revit for tract homes with multiple options/elevations
Tue, May 16, 2006 at 5:07:51 PM
Inserting multiple Families causes project to freeze
Fri, Jul 11, 2008 at 3:28:40 AM
Page generation time: 0.5991
