Forums >> Revit Building >> Technical Support >> how to make a good glass railing
hi, im making a modern home right now and a good looking glass baluster/railing like the one in the picture would be PERFECT. someone please help me make this!
the staircase im making also a spiral staircase, just so ya know
To create the "Glass", use a "model In-Place" Family with a "Solid Sweep", you can create the Rail with the rail tool.
or you can create the glass as a rail
@typhoon, im still rather inexperienced with modeling but im starting to get a hang of it, ill definately give it a shot. thanks!
@mbsteve, are you saying just make the rail extend to the tread of the stair?
make a profile, for rails make it the correct height and thickness, material glass
http://seek.autodesk.com/product/locale/adsk/revit/families/arch/empty/Revit_ARC1853
@mbsteve, thank you very much, i think ive got it down how to make one now
Very nice troy, I have designed those structurally, although the curved glass will be spendy. You might think of using lexan or something like that for the glazing. I think it will be much cheaper to roll.
This stairs was anaylised using finite element technique.
Edited on: Mon, Jan 9, 2012 at 10:37:41 AM
Edited on: Mon, Jan 9, 2012 at 10:39:11 AM
For some reason the above post would not accept the JPG. Maybe this file is small enough to go.
Edited on: Mon, Jan 9, 2012 at 10:42:58 AM
Could you upload the railing you made?
how can i make a glass railing like that please?
