136 Users Online (135 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> schedule that uses dots for a “yes” It can be done.
Wed, Dec 7, 2011 at 11:04:46 AM | schedule that uses dots for a “yes” It can be done.
tmassey
tmassey Avatar
Matrix Schedules
Every so often someone asks if they can create a schedule that uses dots for a “yes” and a blank for a “no”. These are typically used to indicate, "yes we want a particular option" versus "no we don’t". A door schedule might use it for a Electric Hold Open or Automatic Door Closer and cabinets might use it to indicate Lockable Doors. No shortage of possibilites.The answer to this question is a qualified “no”. You can’t choose a “dot” format for yes/no data. Revit only offers Yes/No. It certainly isn’t difficult to understand what Yes/No means when you read it, but people still prefer the graphic nature of a simple dot.This is a long way round to say you can still do it eh? How? Using the Character Map application we mentioned in an earlier post Are You A Special Character? Some fonts have a dot symbol and Times New Roman just happens to have a pretty nice one. There are a couple others like Century Gothic and Garamond but theirs are little wimpy compared to Times New Roman’s. Here’s the character map info for Times New Roman’s dot symbol.So how do you set this up? Easy really, you just need to add the parameters that you require to a schedule, using the data type “Text” instead of Yes/No. Then in the field(s) of the schedule enter the symbol value instead of text. Don’t enter anything when the answer is no. Refer to the earlier post for more detail on capturing the symbol value and entering it. Here’s a simple little schedule as an example.
Using Revit Architecture 2012
Thu, Dec 8, 2011 at 9:41:16 AM | schedule that uses dots for a “yes” It can be done.
tmassey
tmassey Avatar
Steve Stafford's Blog. This is all due to him and I thank him for figuring this out. I meant to put this in the first post
Adding Dots to the Door Schedule
Fri, Dec 2, 2011 at 5:41:20 PM
blue dots in linework
Wed, Aug 18, 2010 at 4:13:09 AM
Gray Dots on My RPC people
Sun, Oct 30, 2005 at 3:26:56 PM
Rendering problem (dots)
Thu, Dec 31, 2009 at 12:00:28 PM
enlarge control dots on dimension witness line?
Fri, Apr 8, 2016 at 10:47:51 AM
Page generation time: 1.2293
