151 Users Online (150 Members):
Forums >> Revit Systems >> Tips & Tricks >> How do you hide the joint lines between different object (beam and wall) in elev
2 Posts No Rating |
How do you hide the joint lines between different object (beam and wall) in elevation-revit.
so that it looks uniform surface
In that elevation view try with "Join Geometry" tool or with "linework" tool with "Invisible lines"
2 Posts No Rating |
thanx dude
15 Posts No Rating |
thank you very much, i was looking for that !
The linework tool is magic sent from the heavens!!
I dont know about. Thanx
Bonnie Binau |
Linework tool is definitely prefered however in some cases it cannot be used (mostly with certain topography lines). Another sort of cheaty way is to override graphics and change the line weight to 1 and colour to white.
How do you hide the joint lines between different wall types? |
Fri, Nov 16, 2007 at 8:16:34 AM
How do you hide different material joint lines? |
Thu, Sep 15, 2011 at 6:53:41 AM
Hide joint lines in 3D and elevations |
Thu, Sep 6, 2012 at 4:08:47 PM
Creating joint lines!!?? |
Mon, Mar 27, 2006 at 10:59:33 AM
Hiding A Beam System |
Wed, May 7, 2014 at 11:28:53 AM
Members: | 1994207 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
