Forums >> Revit Building >> Technical Support >> Adding a more than 3 revision labels in title block
63 Posts No Rating |
how do I add more revisions to my title blocks.... revit 2012 comes with revision A, Revision B & revision C but I'm not able to add more revisions (most of my jobs end up with around 10 revisions... Please help
in your titleblock family, create a new Revision Schedule. You can then stretch the schedule to have as many rows as you want.
thanks absolute BIM - but I am actually after a way to show revisions on my title blocks that arent linked to revision clouds & show up on every page - my list of revisions might be:
concept plan # 1, concept plan # 2, Preliminary plan # 1, Preliminary plan # 2,Preliminary plan # 3, working drawings # 1, working drawings # 2.....
so i am hoping to create new catergory parameters in the edit label mode withing the title block family editor
That is still possible with the standard revision schedule. If you go to the sheet properties there is a Revisions on Sheet parameter that will allow you to select which revisions you want to show up on a sheet, no messing around with rev clouds. That'd be that simplest method, IMO.
Of course, you can do what you are suggesting, but every time I've seen it done it turns out to be a mess. You end up with either a massive list of unused parameters, or you create and add new parameters every time you have another revision. If you go this route, read up on shared parameters. You're going to need to make a whole lot of new ones.
Your on the right path, in your titleblock family, when you create a new label, the "edit labe" box pops up. In here, hit the "add parameter" box. Once you've created all your labels, load into your project.
Once back in your project. You'll have to create the shared parameters which are connected to your titleblock parameters. As TKennedy mentioned, you'll have to read up on Shared Parameters, its too complex to explain properly in a forum post.
I just came across this tutorial for titleblock parameters that may help.
Title Block labels |
Sun, Apr 8, 2007 at 10:04:03 PM
Title Block Labels |
Wed, Feb 14, 2007 at 11:52:49 AM
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:26 AM
Location of Revision header on title block |
Tue, Jul 22, 2008 at 11:24:06 AM
Title Labels [ 1 2 ] |
Sat, Jun 29, 2013 at 12:54:18 PM
15
Members: | 1998332 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
