63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Stair Break Line Customization
18 Posts No Rating |
This may be a simple question but I have not been able to find an answer in the forums. Is there any way to customize the break line for a stair in RA 2011? I am looking to have less of an angle on the break line, extend past the stair into the adjacent wall, and possible even replace the sharp angled break symbol with something more curvilinear? Are any of these even possible?
I have also noticed that the wall directly adjacent to the stair seems to break at a slightly different point than the stair. I suspect this is a result of the top of wall being sloped and aligning with the top of stringer, but it looks confusing in the plan.
No, it is not possible but I think you can lay a detail break over the built in break.
That is too bad. Thank you though.
I need to add a dbl break line to meet the requirements of a proj. barch? any suggestions?
Dr. Zaius: Ah, yes - the young ape with a shovel. I hear you're planning another archeological expedition. Cornelius, a friendly word of warning - as you dig for artifacts, be sure you don't bury your reputation. |
Stair break line problem |
Fri, Jul 17, 2020 at 4:21:45 PM
Stair break line (Revit 2008) |
Mon, May 12, 2008 at 7:43:21 AM
Can't modify (or switch) stair cut line/break line |
Wed, May 11, 2016 at 10:58:08 AM
Break Line & Weld sybol families |
Wed, Apr 28, 2010 at 9:18:41 PM
Stair Cut Line : Double Line |
Mon, May 18, 2015 at 3:19:08 AM
Members: | 1993927 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
