70 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> keynote malfunction in Revit 2010
6 Posts No Rating |
My keynoting function in Revit 2010 is not working properly after I modified the keynote file. I added some catagories into "RevitKeynotes_Imperial_2004.txt" file, save as another file "Imperial_2004-1.txt" and put it in the same folder. I tried to delete the 2004.txt but failed, then I associated my project with 2004-1.txt. When I chose "keynote number - boxed - small" option, it showed text instead of box and number; even after I associated back to the original file 2004.txt and deleted the new file 2004-1.txt I created, it is still the same. Do you have any idea how to fix it?
The text file should not be your problem unless it is built wrong. It should be:
Index <TAB> Value
We have no problems in 2011
keynote categories |
Fri, Aug 10, 2012 at 3:56:23 PM
Multiline keynote |
Thu, Jan 8, 2009 at 2:31:33 PM
Keynote Legend Not Showing Keynote Text |
Fri, Sep 6, 2013 at 11:40:59 AM
12
Keynote Text in Schedules |
Thu, Sep 11, 2014 at 4:45:04 PM
Revit Keynote |
Sat, Sep 6, 2014 at 9:42:20 PM
Members: | 1998323 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
