67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Changing Text Appearance
Any suggestion as to the best way to change the style of text in the all various annotations that come loaded with Revit? Edit each one and reload? Everything seems to be Arial, and we would like to change them to our standard font.
Right, you have to edit the families and save. We also had to go through all of the Revit settings and change fonts from Arial to Times New Roman in all dimension styles, text styles, schedules, view tags, and annotation symbols.
Post edited on 2005-12-02 14:23:23
12 Posts No Rating |
We are running into problems with text when importing Details from ACad blocks. The text lineweight isn't as bold, and the only way we have been able to get it to print darker is to change the font. We could use all the help we can get...
CHANGING SIZE OF DIMENSION TEXT BOX |
Wed, Feb 25, 2009 at 4:22:17 AM
CHANGING DEFAULT TEXT |
Sat, Feb 28, 2009 at 9:53:51 AM
Revit 2014 Schedules display differences between "paper" vs "edit" |
Wed, Sep 10, 2014 at 7:20:59 AM
pipe fitting appearance |
Fri, Jan 20, 2012 at 2:00:17 PM
Changing Text Size in a text box |
Thu, Aug 6, 2009 at 6:41:13 AM
Members: | 2000283 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
