63 Users Online (62 Members):
Forums >> Revit Building >> Tips & Tricks >> tags with editable text???
Good day to all! My predicament involves planting tags. I need to create a tag to decipher between two different tree families: EXISTING & EXISTING TO REMOVE. In my schedule I have them itemized, but in plan view I'm supposed to tag them with individual numbers. I need to somehow put an instance parameter, or editable text. Is this possible using Revit A-2011?
Thanks,
Tres
Sure is - I'm sure each one has a mark number - just add a tag that reads this. I think there is such a tag in the library already.
Thank you so much, WWHub! I've been racking my brain over this and I can't even believe how simple of a fix this was. I must have gone around this a hundred times and still missed it. I had my original set up to read the type mark. Oops.
But, now I can't drag the arrowhead with a grip at the tip. It just dowsn't show up. Can you help me out by telling me how to get this back?
You're the man, WWHub!
Titleblock with 2 stamps and editable text stacked? |
Mon, Jan 3, 2011 at 9:36:13 PM
Sheet Template - editable text |
Thu, Mar 5, 2009 at 3:40:42 AM
How do I add an editable text with a symbol into a project? |
Tue, Apr 24, 2012 at 5:55:01 AM
Edit Section Tags? |
Tue, Aug 12, 2008 at 10:12:50 AM
Editable Text |
Tue, Jun 10, 2008 at 8:43:09 PM
Members: | 1997783 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
