128 Users Online (125 Members):
Forums >> Revit Building >> Technical Support >> Sphere with Windows
Awesome! Glad it worked out.
Okay, for radial array, just select the beam, go up to the array button, and it's set to linear by default. Instead, select radial, then specify a base point for the array to array around... the center of the dome in this case... and then it'll give you the little arm from that basepoint you can select the locationion (in degrees) of the second member of the array group. I just chose 20 degrees, and then used 18 for the array number, giving 360 degrees of arrayed beams in total.
pic attached. Also, if you know what to ask for when you search revitcity, there are numerous threads that cover almost everything. It's an amazing resource. trick is just knowing how to phrase your questions.
pic attached regarding arrays.
18 Posts No Rating |
Thanks once again ismyalterego :-) You have been a great help!!
Regards DS
About sphere truss..HELP! |
Thu, May 3, 2012 at 12:56:26 PM
Need help cutting varying size holes through sphere? |
Tue, Sep 18, 2012 at 3:53:24 PM
One for Mr. Spot |
Tue, Oct 25, 2005 at 8:03:49 PM
Trying to void a spherical mass in 2012 |
Wed, May 18, 2011 at 1:22:23 PM
Can't Cut It!!! |
Mon, Nov 21, 2011 at 2:10:56 PM
Members: | 2000897 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
