62 Users Online (61 Members):
Forums >> Community >> Newbies >> visibility graphics problems-please help!
2 Posts No Rating |
I drew up an arch stamp and grouped it and put it in my titleblock..the problem is that it doesn't show up on the visibility graphics so I can't turn it on or off. Help!
well... inside the family editor you have a "visible" parameter. Add a type parameter from it, and create 2 types, and on one of them uncheck the parameter box.
2 Posts No Rating |
Thanks for your response. Family editor? where is this located? i'm using Revit 2012 and everything appears to be changed around. I clicked to edit group to make sure all the lines, texts and fill are checked visible. It is placed in the detail group which I cannot explain why. Everything shows even when I set up a new sheet, I just can't see the stamp in VV or VG so there is no way to control it. Would it be easier to make the stamp into a family and import it in?
You won't be able to find it in vg.
In the same way you made/edited the titleblock, go back to that location. If you select the titleblock in any views where it's visible, is should immediately bring up a button on the far right that says "edit family."
There's going to be a bit of a learning curve here -- you'll want to look up "on off parameters" on the forums. basically, you can make it so that when you have the titleblock selected, you'll have a check box that can turn off the parts of it you don't want to see. It's pretty handy.
Parameters can be a pain in the butt, but they open up so many doors in revit when you start getting them down.
I had to edit this to say "no pun intended" about opening doors in revit.
Edited on: Sat, May 28, 2011 at 4:34:33 PM
Visibility Graphics and printing |
Fri, Nov 12, 2010 at 3:14:24 PM
Object Style / Visibility Graphics |
Thu, Aug 5, 2010 at 3:21:25 AM
How to apply Visibility/Graphics Options to other drawings. |
Tue, Jan 10, 2017 at 12:54:10 PM
Visibility Graphics - Linked Models |
Fri, Oct 4, 2013 at 7:31:13 AM
Wall and interior elevation visibility graphics settings.... [ 1 2 ] |
Thu, Aug 2, 2007 at 9:29:35 AM
15
Members: | 1987601 | Objects: | 22875 | Forum Posts: | 152177 | Job Listings: | 3 |
